Does anyone know what a 5 speed1.8t tops out at?
theoretically with no wind you should see near enough to 200 mph in 5th on a RR, rolling resistance is an issue tho, you may not be able to hit the limiter in 5thSo the cars top speed is limited to where the rev limiter is set at?Nope, the gearbox ratio has a theoretical top speed, which is well above the top speed of a standard carWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
or the top speed of a standard 1.8T car?
A std 1.8t will rev just as much as a mapped one.
Think about it, at 134 mph in a standard car, your bouncing off the rev limiter, the gearbox has more to give, otherwise how would a modded car achieve over 150
Your box is good for something like 180-190mph, your car wont do that unless you have about 400BHP and strip it down to almost a bare shell, i know that because thats exactly wehat my mates ibiza ran lol
I might ask Nick to do a top speed run next time i get on the rollers,obviously with restriction doesn't apply.
Less than mine! [Does anyone know what a 5 speed1.8t tops out at?
Remember speedo error when you get to those sorts of speeds.Think you would need more than 400 horses or a very long private road.Your box is good for something like 180-190mph, your car wont do that unless you have about 400BHP and strip it down to almost a bare shell, i know that because thats exactly wehat my mates ibiza ran lolWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
LOL.... best place for a 1.8T is off a cliff!9.80665 m/s2
Nope, 203 is the theroretical maximum speed of the gearbox with the above ratios. I quickly goodled 02J ratios and used whatever came up, which could be miles oout lol and with a guessed tyre diameter.So your doing 100MPH @ 3500RPM???
380BHP at the wheels, a weight of just over 800 KG (not including driver) and an indicated 184 on GPS, wasnt on the limiter, just ran out of puff, sounds extremely close to 200 but in reality he probably needed nearly as much power again to get there lolRemember speedo error when you get to those sorts of speeds.Think you would need more than 400 horses or a very long private road.Your box is good for something like 180-190mph, your car wont do that unless you have about 400BHP and strip it down to almost a bare shell, i know that because thats exactly wehat my mates ibiza ran lolWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
Just text him there to ask him the crack and the reply was "it had a 6 speed dog box in it you spanner"Ian
An o2j 5 speed is 23.9mph/1000rpm, so wit a 6700rpm rev limit gives 160mph theoretical maximum.
With a max rev limit of 8200rpm, you get 196mph
An 02m 6 speed is 24.6mph/1000rpm, so this gives 165mph, and 202mph
You'll need a lot of power to get there though. I hit my previous 7800rpm rev limit with my 02m a couple of times in top, but I wouldn't want to do it again.
Your mates Ibeza though either has an astronomical rev limit, or longer final drive, or bigger wheels, as 8200rpm would just about make 186mph with an ibezas ratios.
