21 - 40 of 320 Posts
Discussion starter · #21 ·
... Well just to connect one (or both) of the spare + / - icon buttons on my RS4 wheel so that I can fold them easily straight from there (for example when driving down a narrow lane)
Just to elaborate on my question ......... do you know what a 'temporary' earth pulse signal to the relay would do? Would it allow the mirrors to fold all they way or would they unfold as soon as the earth signal was removed. ? ............ just trying to figure out whether to use just the earth pulse direct from the steering wheel button or run the signal through a latching relay so that the earth signal output is permanent on or off.
You need permanant ground and not momentary
So you need a switch and not a simple button
Cheers Nick .... yeah I can do that with a latching relay to lock the buttons earth signal on/off ... thanks
Nick ...... in your switch mod above ......... are you saying that once you isolated pin 2 (from the track joining 1 to 3) that you then connected pin 2 to pin 4.
If so did you bridge these pins with an additional wire inside the switch (or just outside bridging the wires in the loom) ?
Also ... I did not quite follow this part of your instruction: 'After this transformation needes to reverse the two cables goes to exterior mirror folding motors'
Discussion starter · #25 ·
Hi Patric, the connection of pins 2 and 4 is into the mirror switch. Cut a small cable and solder those to pins.Becarefull the pin 2 has a small surface, dont put soldering paste to the slide surface(place where the rotor moving).
After the end of the modification, you will see that the mirrors do the opozite moving from this we want to do.So remove the exterior mirror painted cover and change the 2 cables to white mirror motor connector.
OK ...understand ... cheers
Well ....did the mod to the switch circuit board and put it all back together ..... and have electrical continuity between pin 5 (earth) and pin 4 within the socket when the knob is turned to the folding mirror position .... so all should be OK for the earth signal output.
Still need to do the whole folding mirror install (using the audi 361 relay) mod so can't test it fully yet though ... but if it works as per the video it will be great.[Y]
Discussion starter · #29 ·
I'm presuming that #79 relay could be changed out for any 4 pin relay? #53 Would presumably do just the same job or is there something special about 79 that I'm missing?
Hi Mate , 53 relay is 4 pin relay , the 206 relay is the same with 53 but do the opozite work.The 79 relay is the 53 and the 206 together.
So the 79 can be used as 53 and also as 206 relay
.For this mod you can use the 79 or the 206 relay
That good modification!
I was looking for the same thing for my car.
If I may ask:
This modification is performed after placement of the relay 361 in our mk4?
This plane is the one that I found to install my mirrors with audi relay 361 and adding a pair of relay investors to work properly the motion controller mirrors:
I can use that plane and add the solution proposed by the creator of this post golfmk4gr? Or install the relay 361, another more effectively.
Watch your videos on youtube modifications, are great golmkgr!
I found this thread looking for information and I found a great forum full of content and to improve our VW.
Greetings and thank you very much.
We introduce myself properly in the forum.
Hernan.
PS: sorry for my English is pretty basic
Discussion starter · #36 ·
If I may ask:
Hernan.
Hi Herman, if you want to do this mod , you have to install the 361 relay first.
There are 2 ways to install power folding mirrors to your car. The first one is via 361 relay and the second one is with vw original windows motors with power folding function( original way). If you choose the first one( non original) , with 361 relay , then you can do my mod with remote folding mirrors.
Nick
Thank you very much for responding!
Do not install my mirrors yet. No purchase order received yet.
I'm looking for information on how to connect everything. And his mod surprised me.
I read about the two ways to connect the mirrors and opt for the 361 relay for a lower cost item.
According to what I found recommend installing this way to avoid conflict in the control operation of the mirrors and one of them:
http://imageshack.us/photo/my-images/41/instalacinrele361.jpg/
Where investors are placed two relay and a switch to override the relay 361 and allow it to be adjusted from the command mirrors door.
But asked if you have it installed well. Or I do it in a more appropriate and getting all the features to run perfectly.
Thank you again!
Discussion starter · #38 ·
Thank you again!
This diagram , show , how the 361 relay can work together with original window motors with power folding mirrors function.
I dont use those window motors .Just the 361 relay and the 79 or 206 relay.
Then he made the connection in this way for audi relay:
Relay ............................................. .................. Mirror connector (T12)
Pin 4 = 15th .............................................. .... .... fused +
Pin 5 = Motor for folding mirror (-) left / right ............. T12 / 1
Pin 6 = ............................................... .. ............ Earth (-)
Pin 8 = Motor for folding mirror (+) left / right ............. T12 / 2
Pin 12 = Switch for Folding Mirror ________________ Safe Signal (-)
Pin 14 = Switch for end of folding point (microswitch) in mirror left / right - T12 / 3
Mod and added its control gate.
If so, I look forward to the arrival of my mirrors to install in my variant.
Thanks Nick!
Discussion starter · #40 ·
Thanks Nick!
The connections looks ok.Try the installation and you can post here your results.
Good Luck
Nick
