Does anyone know what a 5 speed1.8t tops out at?
well I'd like to know that if its differentthe 5th gear ratios theoretical terminal speed?
Nope, the gearbox ratio has a theoretical top speed, which is well above the top speed of a standard carWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
or the top speed of a standard 1.8T car?
A std 1.8t will rev just as much as a mapped one.
So the cars top speed is limited to where the rev limiter is set at?Nope, the gearbox ratio has a theoretical top speed, which is well above the top speed of a standard carWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
Think about it, at 134 mph in a standard car, your bouncing off the rev limiter, the gearbox has more to give, otherwise how would a modded car achieve over 150
Your box is good for something like 180-190mph, your car wont do that unless you have about 400BHP and strip it down to almost a bare shell, i know that because thats exactly wehat my mates ibiza ran lol
theoretically with no wind you should see near enough to 200 mph in 5th on a RR, rolling resistance is an issue tho, you may not be able to hit the limiter in 5thSo the cars top speed is limited to where the rev limiter is set at?Nope, the gearbox ratio has a theoretical top speed, which is well above the top speed of a standard carWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
I might ask Nick to do a top speed run next time i get on the rollers,obviously with restriction doesn't apply.
Less than mine! [Does anyone know what a 5 speed1.8t tops out at?
Remember speedo error when you get to those sorts of speeds.Think you would need more than 400 horses or a very long private road.Your box is good for something like 180-190mph, your car wont do that unless you have about 400BHP and strip it down to almost a bare shell, i know that because thats exactly wehat my mates ibiza ran lolWouldn't that be the same thing?Do you mean the 5th gear ratios theoretical terminal speed?
