does anyone one have a how-to for fitting the powerflex bushes for the dogbone mount. i'm doing mine in the morning so if anyone has any guides for doing this i'd appreciate it
Yes mate.. listen resist a little. i drive alot in traffic i.e. stop start.. 1st 2nd gear mainly.. just to gauge 7 miles takes me an hour to get to work.. so thats alot of stop starting and already its started to lessen drastically.. you see theres a trick to stop it vibrating over rev a little when your pulling off but it defeats the object as you dont let the engine virate alot and crease the poly bushes.. but if you pull off as you would do normally and let it vibrate to high heavens then gradually you will notice it gets alot and i mean ALOT better.. not disapears taht would be lying but ive only done 100miles and im sure it will not be as disturbing after a couple hundred more..so your saying mine will get better then ?i didnt wana spend 60odd on the r32 but mine vibrates alot on pull away etc
