Golf TDI 130 - Serpentine belt - tensioner pulley bearing - noise at low RPM (under 1000RPM)
1.6K views 10 replies 9 participants last post by  Jamie8954
#1 ·
Hi,
A rattling noise started coming from the engine bay yesterday and I think its the bearing that for the tensioner pulley on the serpentine belt (belt that comes from alternator, air-con, power-steering). Thats seems to be where its coming from.The noise only starts when the steering wheel is turned. The rattling noise is pretty bad when the engine is idling (under 1000 rpm) if the put boot down slightly the noise drops off quite a bit. Just wondering has anyone had similar problems. Im taking it to a garage after work to see if thats what is wrong for sure. she has 126K on the clock now, im not sure if the pulleys were ever changed.
I was getting alternator light a couple of weeks ago that came on once or twice and then never came back.
Could be something seizing up in there?
thanks for any advice
#5 ·
Sorry I dont know the numbers I went to VW and asked them as they can check what alternator your car has fitted and then just got the pulley, as the for the tensioner I got a local garage to do it as its a bit of a pig to do in fact he did both because the alternator pulley if it can be changed is also a pig to do but is a lot cheaper.
Stu
#7 ·
Had this job done on my tdi 150 last week. The free wheeling alternator pulley was fcuked and this in turn ruined the tensioner. its a common fault.
New items from VW was ÂŁ70 for the pulley, ÂŁ38 for then tensioner and an hours labour. (ÂŁ40 in my local VW independant. So about ÂŁ150 should cover it.
regards, M
#10 ·
If you change the tensioner the sound will go away for a while but it's nearly always the alternator pulley. Change both and move on.
Eurocarparts stock both for around ?40-50
