1 - 13 of 13 Posts
hi after spending 1100 on a new turbo to my gt tdi it seems to have genarated a new problem
it will out of the blue run realy badly wont rev and the traction controll light comes on but only for a while its done it 3 times in the last week
has anyone got any clue as to what this could be
thanks billy
i keep trying but my laptop is acting up
i have just looked im the car and it has lost its engine managemet light too
its all since its had the new turbo
Sounds like a speed sensor issue. Scan the car and see what turns up. Have you had any of the wheels off recently, for any reason?
they took them off when they changed the turbo
so do u mean the car thinks wheels are spinning and puts traction control on
im trying to install vagcom on my other laptop but its giving me greif not sure why maybe its vista upsetting it
so do You mean the car thinks wheels are spinning and puts traction control on
Do you mean they had the wheels off and /or the speed sensors?
Basiclly the car thinks the wheels are skidding and as such brakes the wheels it thinks has traction and bypasses the throttle and takes the revs down from the engine.
If they took the speed sensors off and didn't seat them properly when they reinstalled them this can cause issues with the ASR/ESP. It's an easy job to check them which you should do because they may have also damaged them during thier removal and installation. Also check thier wiring cause something may have been knocked or broken during the turbo installation.
Best thing to do is take them out, check if they are damaged, if they're ok push them back in all the way to the end and then pull them back a fraction so they aren't right at the bottom of thier housing.
Try a scan but if it's a speed sensor issue I'm betting there won't be any codes thrown because the car will be behaving like it should do cause it thinks it's loosing traction. Have you tried turning your ASR off via the button in the dash? does this solve or lessen the issue in anyway?
this is what i got from vag scan but it seems to be in strange language but i think the codes are there if anyone can sus them out
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CJ
Component: 1,9l R4 EDC 0000SG 1086
Coding: 00002
Shop #: WSC 00028
3 Faults Found:
17965 - n"q`5_]{†f~gýh2.0CJ=~f.-³.Y+*IC0øÅ?taÒ³Rßan
P1557 - 35-10 - f - Intermittent
17552 - ƒL?ò•E8L›,@Ba+„p"[;=&[email protected]„t/ƒvWH"´ 4lóƒikmì)R|ñMÅz6þó
P1144 - 35-00 - f
18075 - ksJk2e-[p÷I¹Gv+a4dÿ[email protected]û›SÔ´ÞQ5oYh4gsvù]-UuBgÏ_¨kT([email protected][)t§6nL-NW
P1667 - 35-10 - f - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00028
1 Fault Found:
01314 - ¡'M?Õ;7pQDiU7JXf"÷-ß9
013 - ?4LâÞ{#|@xkÐ_1M× - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 926 C
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 07422
Shop #: WSC 00050
WVWZZZ1JZ2P032811 VWZ7Z0A3724772
1 Fault Found:
49-10 - h6ZI[UåôŠ{(sÏRùi[ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1X Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00028
1 Fault Found:
01135 - Z4 fñe'?6L_^Ðq/^.{wìZ7æ'Nw¶
36-00 - ôtjÛ2v? 0þMK
End -------------------------------------------------------
The fault code is the 5 digit code next to the gobbledegook. Write the code.down and go to the Ross tech site and use their Wikipedia function to find out what the.codes are and report back here if you need more help.
I can see the letters asr somewhere in there so I'm putting my money on the speed sensors and possibly an abs pump fault which is more than likely a dodgey fuse connection on top of the battery box.
Diesel isn&#39;t a dirty word
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
  • Reduced power output
  • Limp mode
Possible Causes
  • Boost Pressure too High
  • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
  • Charger Pressure Control defective
    • VNT (variable nozzle turbo): nozzles stuck
  • Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check / Clean / Replace Charge Pressure Control
    • Check / Clean mechanism for variable nozzles
18075/P1667 - Valve for Pump - Jet: Cylinder 2 (N241): Electrical Malfunction
Possible Symptoms
  • Irregular rpm
Possible Causes
  • Wiring and/or connections to/from the Valve for Pump Jet
  • Valve for Pump Jet
Possible Solutions
  • Check wiring and Check / Clean all connections
  • Replace the cable-tree to/from all the Valves for Pump Jet
  • Replace Valve for Pump Jet (replace them all !)
Special Notes
  • For each Valve the ECU checks the Begin of Injection Period (BIP) via a voltage. That voltage is very small (less than 0.0001A). Each extra resistance in the cable is fatal. So, in case of any doubt, just replace all cables.
01314 - Engine Control Module
01314 - Engine Control Module: No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
  • Check Engine Control Module for Fault Codes
Special Notes
  • Engine Control Module stored a Code which influences other Control Modules Functionality.
  • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
    01135 - Interior Monitoring Sensors
    01135 - Interior Monitoring Sensors: Open Circuit
    Possible Causes
    • Wiring/Connector from/to Interior Monitoring Sensors faulty
    • Interior Monitoring Sensors not installed
    Possible Solutions
    • Check/Repair Wiring/Connector from/to Interior Monitoring Sensors
      • See Measuring Blocks
    • Check Interior Monitoring Sensors Installation
Looking at those, first thing I'd do is clear all the codes and then re-scan the car preferably using an english version of vagcom [;)]
The 01314 errors could be due to the clocks being out or battery disconnection, the one to look at is the firts one 17965 as that is normally sticking VNT, faulty N75, split vac hose or badly adjusted actuator mechanism.
You need to run some logs on measuring block 11, see the sticky VNT link in my sig [y]
As your turbo is new then the actuator might not be set up right rather than sticking VNT
Neil
thanks for your help neil not alot of that made sense to me
i think the vtn problem has been sorted with new turbo but fault never cleared
i need to find my old copy of vag com in english but i reformatted my laptop and lost it
do u have ant idea why my eml has gone could the bulb be gone or are the clocks on the way out or somthing
billy
just scanned in english here it is
and now cleared errors
and i dont know if i should have done this but i went on 01 engine and tested with the button that trys everything just trying to check the eml light but it tested things lie actuator and stuff hope it dont hurt anything
Scan: 01,02,03,08,15,17,19,22,35,46,56
Coding: 00002
Shop #: WSC 00028
3 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
18075 - Valve for Pump-Jet: Cylinder 2 (N241): Electrical Malfunction
P1667 - 35-10 - - - Intermittent
Readiness: N/A
Coding: 0021505
Shop #: WSC 00028
No fault code found.
Coding: 07422
Shop #: WSC 00050
Coding: 00006
Shop #: WSC 00028
Coding: 00259
Shop #: WSC 00028
1 Fault Found:
36-00 - Open Circuit
1 - 13 of 13 Posts
