I checked my V5's cooling fans today and they are no longer running on the low speed. I've disconnected them and checked the fans by themselves and the internal resistors are burnt out on both fans.
I have reread the posts by Andymac and others about this problem and I have decided to fit external resistors to repair the low speed function.
From Andymacs previous posts it looks as if the resistor for the bigger of the two fans is approx 0.8ohm.
I have just tried a 1 ohm high power resistor in series with each fan and measured a current of 7.0A (with engine running) for the big fan and 5.5A for the small fan. This means that the big fan will need a minimum of a 50W resistor and the small fan a 30W resistor.
My question is, has anyone actually measured the low speed current drawn by each of the fans when running with the internal (unbroken) resistor? If not does anyone know the internal resistor values for both sizes of fan?
I will publish details of this mod when I have finished it.
