1 - 20 of 20 Posts
One of my window clips broke today, managed to get the window back up
though.Can anyone tell me how much itis for the repair kit and where
from? Thanx in advance for any advice.
Hi Peeps,
Soz to hi-jack post but in the past 12 months I've had both mine done - 1 by a main stealer and the other by a local garage. My car is 5 years old and done 72,000 miles.
If I contact VW direct am I likely to have the payments refunded? Maybe at least for the payment to the main stealer?
Phil
Mine have gone too,does anyone know how easy they are to fit? i'm guessing they would be quite difficult?
They're not that bad really. It is a two man job i'd say to get the window in while it's manouvered into position into the clips. Just a bit fiddly to get the new clips onto the wire etc.
Fitted the repair kit today. Easier than i thought it would be, only
took about an hour. Phoned one 'stealer' and they told quoted me
£65+vat, phoned my usaual vw garage and it was £28+vat
Mine broke just after I left home for Edition 38 the other week had to turn back as the glass had fallen into the door, I bought the repair kit in the week and have now installed it all on the internal door panel but just haven't got around to puting it all back together, currently the glass in my door is being held up with bits of wood, but I'm not using the car at the mo so I'm not bothered.
How difficult is it to get it all back together on your own?
There is a fitting guide on vwvortex.com or if your car is less than 6 years old your dealer will do it under warranty.
Had both my fronts done in the last two months FOC. As Dsgwagen states, its free if the car is less than 6 years old.
6 years and 90,000 miles and they will repair for free !!! i had mine done
Jay
is this right at 90k miles? as my car is 2000 W reg so is over 6 years but only 46kmiles on clock
I'm also intrigued by this[*-)] as my passenger side window is very slow.
Do VW replace the clips both sides? And does your car have to have a VW warranty for this work to be done?
If i can get this work done for free then Whey-hehh!! as i am dredding the day when my window drops out.[:p]
GOOF
one of my rear windows made a huge crack noise when was being used, glass went up ok and the window hasnt been used every since. this was in june/july somtime so if vw would replace mine then also wahey!
i might give vw a call
my driver side window fell so i got the clips so i changed it but found out the cable been chewed up and not sure what to do should i buy the full kit think it was 70 pounds but not sure whats in the kit
1 - 20 of 20 Posts
