1 - 13 of 13 Posts
as above what pressure washer should i buy as they range from £35 upto £300!! I see people use a snow foam method, which lance should i use and the product to buy.
Secondly, if i buy a product such as autoglym shampoo can i use it with the snow foam lance to cover the cover then manually rinse off, and the same goes for demonshine. Basically, i am asking can i use the snow foam lance with other products to cover the car?
I had a karcher k2 series and it worked fine although the plastic pump is a weak point. The cold weather killed mine. Lasted 2 years.
i think most of the 2 series have brushed motors that wear out quickly compared to the more expensive types.
In fairness, mine was the cold weather - cracked the plastic casing of the pump. It still runs but water is pouring out of it so the pressure isn't great. Might have a look to see if it can be repaired when I get time.
1 - 13 of 13 Posts
