1 - 20 of 20 Posts
Which engine is fitted to your MKV GT TDI ?
AZV
BKD
They are both 103 KW but might explain why some people get mpg figures like 42 and others 55+
AZV
BKD
No-one is getting 55+ as an average I don't think.
The one fitted to my car is a BKD and the best i can get is 43 mpg, it's not chipped and that's driving to get the best mpg
Some people on here have posted if not 55 mpg, a lot more then 43 mpg
how do u know what one is fitted ?
i can get 53 as an average when taking the parents out or taking it easy
find i get better on normal roads where i am not tempted to speed alone like u do on the moterway
I am [:D]
If i do a motorway journey of 50miles at a steady 70 i can push 60.
I usually cruise at just under 80 and return 52-54, since i passed 20k i havent had less than 50 average on a brim to brim. Not sure which engine i have though
Mine is BKD
I get between 42 and 44 mpg
What's the difference bewteen the two ?
I've got a BKD, current mileage = 2450
Average to date: 50.3 mpg
Motorway at 80 ish = 45 mpg 75 ish = 50 mpg
Motorway at 80 ish with a headwind = 42 mpg
Motorway at 50-60 with a tailwind = 55+ mpg
Factor in uphills and downhills, ambient temp. and driving style, and it's virtually impossible to draw comparisons (IMHO).
On my avergae drive to work(35 miles) I get between 50 & 55 mpg on average, I have managed to push it up to 60 on a couple of occassions driving carefully.
I would say I have a fairly average driving patten.
I get roughly the same on the way back too.
These figures are not what I would consider average, I would say a balanced mixture of town/motorway driving is average for most people.
I can get 50mpg on the motorway in my 1.6FSI, record 53.3mpg.
Mines not just motorway driving,
On my drive to work, I drive through one town into country roads, rounds the lovely reading M4 round about, sit still on the m4 for a bit, drive a bit, get to slough and then sit in traffic there.
Thats why I consider mine to be pretty average for a commuter
I suggest its more to do with how we define 'average'. For example I always aim to get at least a 50mpg reading in the average fuel consumption part of my trip computer on each journey I do that is longer than a couple of miles. I pretty much always achieve 50+ and very often its nearer 55mpg when I keep the speed down on the motorway. However this is the individual journey computer (1). If I flick the rocker switch below the right hand stalk and look at screen 2 which has not been re-set since I had the car then the total mpg average is something just below 46mpg.
I have never been able to achieve a 60+ figure under any circumstances yet and find that even 50+ becomes elusive if the speed goes over 70mph. Perhaps a 50 mile motorway crawl at 55mph would do it but I am just not that patient!
Lets not quibble about whats meant by some words.
I had hoped to find out if there was any relationship between MPG and the two GT TDI engine types fitted to the MKV Golf
My car get's driven in an average to heavy footed way. It is usually loaded with heavy samples in the boot and it gets used to get around not to nurse the mpg computer. I think that in mind my mpg of around 43mpg is good and I am very happy with it. I expect to get more like 45mpg with a few more thousand miles on the engine.
I am still curious to know what the differences are between the two engine types? or is it just where they were made?
Without some comprehension and agreement of what is meant by 'average', you will not get any meaningful information. I will however check to see what my engine code is.
If you read my post, these were example figures and i also quoted my brim to brim average. My daily commute involves about 10miles in slow traffic, so i consider i have a wide range of driving over a full tank.
The other day i did 300 miles, probably 200 motorway at 80-85. 40 around town and 60 absolutely hooning it on A roads. I returned an MFC readout of 55.4mpg,
I'd like to add my own fuel consumption figures for my GT Tdi (BKD engine). I have done 10,000 miles in six months from new with a ratio of 80% : 20% long/short journeys.
The first things I check on new cars and periodically thereafter is the accuracy of the mileometer and speedo. My mileometer overeads by 0.8 of 1% (not much I know but it builds up with the miles) and the speedo overreads by 2mph at 30mph and 4mph at 70 and 80 mph.
My overall consumption is 49.9 mpg with a low of 45.4 and a high of 54.5 - keeping to speed limits (more or less)
The 54.5mpg was achieved at a steady 65-70mph over 280 miles on a level motorway.
As we all know the GT TDi is a heavy car at 1451Kg. I sued to think that my mark 3 16V GTi was quite heavy at 1165kg but the difference between the two is equivalent to carrying four 12 stone passengers in the 16V!
Therefore, making full use of the performance - that massive torque equivalent to that of some high performance cars - or driving in hill country does obviously use a lot of Diesel to produce that oft quoted 320Nm /236lbft of torque. Switch the MFa display to instantaneous fuel consumption (not particularly relevant overall) and you see how the
reading plummets when you approach a gradient
Regards ot fellow TDiers
Col, your figures seem amazing compared to mine and others.  If I cruise at 80mph on a motorway I will be getting low to mid 40's mpg. To get the average for a trip to end up at 50+ I need to be driving very sedately indeed, certainly well below 60mph as ecconomy is quickly lost once yu head towards 70mph+. Have you verified these amazing figures by working out how much fuel you are using brim to brim in comparison with the miles driven as it looks like you are getting nearly 600 miles between fill ups which is 100 miles better than I have ever got with very careful, (legal speed) driving. Just curious.
How many people leave the aircon on? I reckon I lose 3/4 mpg, esp. at higher speeds with it on, so other than hot days (yeah right!) I keep the green Econ light on, except when de-misting of course. Maybe it's a throw back to power sapping aircon from the 80s (I used to live in Australia), but I always switch it off when overtaking on A roads or when I want every ounce of power.
Mine is BKD
The BKD seems to be fitted to the 4 Motion & the GT TDI or what ever it's called, and has
ECU 03G906016FM PR
G0K+0GG
ECU 03G906016AQ PR
G0L+0GG
ECU 03G906016HJ PR G1A+0GG
and the
AZV has an ECU 03G90606FL PR G0K+0GG
or
ECU 03G90606HH PR G1A+0GG
Can someone from the dealer network find out/let us know what the PR numbers are?
1 - 20 of 20 Posts
