Quote: posted by Mikedav on 05/04/2005 17:47:06
How did that happen???
Not sure on the way down had a little fun around the A43 circuit,
Nothing heavy really, too busy with morning traffic.[^]
ESP kicked in a few times but nothing went bang or seemed to stop working, weird.
Had new HALDEX ECU on it before xmas also.
Here?s the VAG-COM
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 022 906 032 E
Component: MOTRONIC ME7.1 0008
Coding: 00132
Shop #: WSC 31414
1 Fault Found:
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
Readiness: 0000 1000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 F
Component: ESP ALLRAD MK60 0103
Coding: 0023046
Shop #: WSC 31414
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B2 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 31414
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 925 A
Component: KOMBI+WEGFAHRS. BOO V04
Coding: 05414
Shop #: WSC 00735
Ident.-Nr.
WEGFAHRS.:VWZ6Z0Y2025816
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31414
Address 22 -------------------------------------------------------
Controller: 02D 900 554 D
Component: HALDEX LSC ECC 0011
1 Fault Found:
01155 - Clutch
04-10 - Mechanical Malfunction - Intermittent
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 4V Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 31414
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 01403
Shop #: WSC 31414
End -------------------------------------------------------
