1 - 2 of 2 Posts
Fast or low and slow, that is the question.
Hi Damian I was wondering if you could help as I'm a little stuck.
Basically I have a set of RS's that have been re-drilled to 5x100, due to the larger center bore I now have to use narrow tuner bolts. Now I am stuck as I need to fit some 15mm spacers to get the right offset but first of all I cannot find bolt on spacers for 15mm that will sit completely flush as the back off the wheels have no recesses and I cannot find longer tuning bolts.
Any help would be hugely appreciated.
Here are a few pics if it helps
1 - 2 of 2 Posts
