1 - 13 of 13 Posts
I have a 2000 Bora TDI 115SE with 110K on the clock
Rides like a pig, I imagine the whole suspension set up is shot and needs replacing, the engine is sweet and body fine, should I invest or get shut, any Ideas of the cost?
you can do the suspension for cheap, maybe get a set of coilovers and thats sorted. if the engine is good and there is no other problems apart ffrom the suspension then you should keep it imo
LOL
Whats cheap?
Bushes ,dampers,top mounts, fitting, labour... surely it all adds up
Deffo not loweringtho, the roads in East Lancs are shocking.... no pun intended!
as said above can get shocks, springs and everything you asked for a good price, cant say how much exactly as I never bought all of them, have a look on the classifides mate [Y]
and to keep costs down fit it yourself
pauly4226
keep and play my friend. wishbones,?30 ish each, sports springs,a slight drop but very user friendly,track rod ends? 10 each, dito top mounts buy a haynes manual ,and try my friend
jom coilovers £160 dont slam it.
as pauly said, wishbones, £30 each,
everything can be done at once. will make the job easier tbh. labour wont be much. [Y]
Ill have it off you if its going cheap.
Even to strip and replace everything suspension wise is less than a weekends work. Would be crazy not to fix it.
TRL
Not sure what the coilovers are like, they lower 30mm
I did all this on my GTI way back in 1992, it was a disaster
would standard shocks n springs be as cheap?
In that case you should just give it to me. [:D]
Coilovers are gash. Stay away.
Shocks and springs all day everyday.
Ebay is where its at my friend. EBAY!!
1 - 13 of 13 Posts
