1 - 19 of 19 Posts
here goes again! it seems like i got 1 problem after another.
the problem now is that my car shakes now even at idle, when i go driving it shakes aswell like it judders.[*-)]
waht could be the problem?
please please help
many thanks
MAX
1 of the Coilpacks mate mine done it last week there about ?25 each plus fitting and there is 4 of them.[:D]
U should only have 2 replace 1
hmmmmmmmmm im taking it to one of ma m8s garages 2mo but he did
mention that it could be summink to do with the coil pack, so hopefully
gonnaget that sorted.
thanks everyone.
MAX
Just called the RAC out tonight with a similar issue. Also noticed a hissing noise on idle, and HE found the vacuum pipe had come adrift. Put it back on and cable tied it for better attachment and all is well.
The vacuum pipe was between the engine and the cooling fan, and it simply pushed onto a green connector!
AnilS.
Mine does the same and has been doing the shake at idle since the engine came out for a new clutch in. We have almost got to the bottom of it and it looks like it is the dual mass fly wheel. And it is v expensive at the dealer.
Could be engine mounts. If they're buggered then there's nothing to absorb the vibrations of the engine thus transmitting it directly onto the chassis.
Mokeylock
AnilS.
Cool Ying Yang
got the car back from garage 2dy and its doing ma head in now! the
dude at the garage first thought it was the coil packs so he chaged
that then he had a lookat the maf so he changed that then the lambda
sensor and changed that he checked out the wiring and thats all fine so
he ran diaognostic aswell and fixed all my error codes but stillit had
the same problem so the dude said that it might be summink to do with
my ecu?[:S].
he said that hell fit in another 1 from the same golf and if its fixed that means my ecu is buggered.
got sum1 from AA cummin round 2mo to get a second opinion!
my ecu?[:S].
Guy doesnt know what he was doing... should nt have changed anything unless error codes said to... he should have cleared them all first then driven then found what was wrong....
basically he needs to log the parametrs on the maf/o2 sensor/lamda sensor/water temp sensor/coilpack misfires .
any one of these outside parameters can make the other throw a code when really it is ok... the ECU will not be knackered ... if the ECU was Knackered it wouldn't run at all, ecu's never partially fail... it needs looking at by a vag specialist with vag com or a 1552 tool... not some crappy fault code reader that cant do live logging
Are you sure its not the flywheel?? Mine does exactly the same and no error codes etc come up. When you pull up slowly at traffic lights you can feel the car move very strangely!
Good point!! Could be the dampers in the duel Mass flywheel that are knackered [:(]
When that happened in my Clio, it turned out I had unburnt fuel in the oxygen pipe!
Don't know if that is relivant for Golfs too [:S]
i want to cry now!!!!!!!!!! [:'(] got the a m8 from the
aa round the other day and he said that one of the coil packisnt
working ( the 4th 1along) so hes taken it to his houseto fix it coz hes
got a drive! hope he fixes it. i regret giving it to the dude in the
first garae nowjus went over his invoice for the work he did onmy
carand it seems hes charged me alot for doing sh*t!
hopefully should be fixedby monday.
pray for my car every1.
MAX
Mate,
As Andy mac said, ecus dont partially fail.if the coilpacks have been checked and are ok, (the mechanic should have ideally
swapped each one out in turn to find the faulty on), he should be looking at the ignition amp that sits on the side of the air filter
box.This amplifies the signal from the coilpacks to the ecu.If this is buggered then it will cause all the problems you describe.
This is what he should have also swapped out to check.Id get on the phone to him and get him to test this before anything else
is done.
Mate,
is done.
You could also try (as a basic remedy) cleaning the contacts on the coilpacks and the ignition amp.. mine was juddering and misfiring inconsistently for ages until I did this and it's been fine for ages since. Maybe as simple as this though I doubt it, but it's gotta be worth a try !
hello!!! [:D]
i have finally got it fixed. got ma m8
from AA to check it out. he said it was summink to do with the
inginiton module ( inginiton amp) or summink.
wooohhhoooo. finally can start tp plan re-map and exhuast.
thanks every1.
MAX
1 - 19 of 19 Posts
