1 - 6 of 6 Posts
Hi
Have seen the mod done a few times, where you can shut or open the windows using the remote, if you hold the lock button on the remote they shut and if you hold the unlock button the windows come down.
I remember this used to be done using a DOS program called VDS Pro, with a laptop with a serial connector and an old serial to OBD2 lead.
I have a copy of VDS Pro, but my laptop doesn't have a serial port, only USB so I wanted to know if the newer versions of VAG-COM/VCDS can do this mod.
If anyone in the surrey area can do this mod for beer tokens then please pm
Dub
Nope only VDS pro on a serial lead or the KW100 module at £40 + a throw
I've seen these modules. Are these a one time thing or can you use them on more than one car. Also I have an old laptop with a program thats completley in polish that will do the window mod using a usb cable, literally plug obd2 cable in and hit one button, thats it. only problem is the laptop failed a few months back and I can't remember what the program was called.
1 - 6 of 6 Posts
