Afternoon all
What price should i be paying for a garage to fit eibach dampers and springs to a mk4 golf?
cheers
Deano
Hi,
?100 to 150 would be fair.
Failing that if you have a night/day to spare and you want to learn how to do it to save yourself some cash let me know, I dont mind giving some help/instruction and a loan of my tools.
Also while doing the job replace the Suspension Top mount bearing and bushes, For the cost also order all bolts removed as well.
For the cost from VW, Cant remember the exact price, I think its ?30 ish for the lot.
There is a rubber top mount, A bearing that kits in this. (These will almost certainly be worn out)
Lower Shock retaining bolt that passed thru the hub will also be needed. The rest should be fine with a drop of loctite
dunno what rates are like up there, but allow 3-3.5hrs for this + tracking
Down south, that equates to about ?200+ at non franchise garage
sorry for the hassle i'm totally rubbish when it comes to parts. Where can i find the part numbers that i need or will the person at the parts bit in vw know what i need?
sorry again
I paid ?117.50 to get my eibach springs and Koni dampers fitted to my car, which wasnt too bad I didnt think. Would have preferred to try it myself but didnt have technical know how!
Andy
vw wanted ?300+ to fit mine!
so i did it myself
you'll need a spring compressor (?10-20), and some of the bolts for the driver side of the subframe as it'll need dropping a tad
We compressed the coil spring with spring compressors to reduce its length to give enough to get it out. Was a while ago now i did it but it all went pretty smooth.
Refitting was obviously easier as the length of the shock is reduced anyhow.
sorry again
Yes just tell them the names of the parts and they will know what you are talking about
hmmm, when i took mine out it was impossible to compress the spring anymore (due to fitting the spring compressors in the arch) and i actually found other people that said the subframe needed lowering, so thats what i did
Wen't down to the dealers today and came back with these:
are these the rights parts???
Thanks guys
Deano
Yep - for the front, although you also need the nuts for those bolts (to hold the damper in place).
For the rear, you need:
2x lower damper bolts
2x lower damper nuts
4x upper damper mount bolts
Cheap as chips
