1 - 3 of 3 Posts
Knows nothing about cars, even less about Golfs&#3
got told my car when on it's MOT 6 months back, had some play in the steering rack in the advisory.
nothing to worry about the bloke said.
just wondering what exactly it is and no doubt the stupid cost associated with it! lol
cheers
If you sit with the key in the ignition and it turned on but without
the engine running give the steering wheel a slight move in either
direction as if you was trying to turn.
You may get a slight feeling of it doing nothing as if its not
attached (over a range of about 2-3 degrees).the problem is where the input from the column goes into the rack the
gears wear and it causes play.
(copied from that topic)
Click
you should use the search button more often [Y]
cheers, kind of costs associated nowadays?
1 - 3 of 3 Posts
