1 - 20 of 34 Posts
Premium Member
Sat still in traffic last night and the engine started idling erratically and shaking badly, moving off there was little power and engine felt lumpy, and sounded like a tractor, any ideas what could be the fault? Felt like an engine mount with the way the car shook but that wouldn't cause any power loss, MAF was replaced last month.
David,
I see you have an AGU like mine [:D].
Did it feel like a miss-fire ? Could be your intermediate stage on the back of the airbox, take the connectors off and clean up the contacts. Scrape them with a blade or use some emery cloth. I use spray contact cleaner on the loom side.
Give that a go.
Paul
Premium Member
Yeah, does sound like a miss-fire.
There's 2 connectors on the airbox isn't there, is it one of those two?
Yes there is a module bolted to the back of the airbox with two connectors, you need to clean them both up, to release them you push the small metal bar in and the pull the connector off.
Paul
Premium Member
I had this last year....exactly like you stated above. Very little power, engine idle all over the shop.
Might be, happened last night in that big downpour so something could have got damp.
Cheers Paul, i'll try cleaning those connectors tonight
Premium Member
No luck. The car feels exactly the same with the MAF dis-connected too.
I had a similar problem on my car a few weeks ago.The AA Checked the
coil packs, plugs, compression, ignition amp module thingy, injectors,
all were ok and i had no CEL on the dash.I also tried disconnecting the
Maf and swapping out the temp sender and still no change.
When i let the car cool down it would start fine with no misfire.A few minutes down the road the misfire would return.
Took it to a bosch injection
specialist and turned out to be a faulty ecu.Had to send it off to repaired.
how did the car behave when you disconnected the maf?
If it was the maf it should drive better unplugged. You will boost less tho.
Worth a try if you have not tried already.Do you have AA or equivelent membership ?
Same as mine was.Does it still misfire when starting from cold ?
Id call the aa out and get them to give the car a look over.They will
be able to hook it up to their diagnostics laptop and check for faults
too. I was reluctant to call them out for my car a few weeks back
but was glad i did.Really impressed with the service i got from the guy
that came out to my car.He really gave the car a proper check over and
although he was unable to find the problem he was pretty sure that it
was an ECU fault and he turned out to be right.
Worth a stab before you fork out any money changing parts.
1 - 20 of 34 Posts
