1 - 4 of 4 Posts
Just noticed my clutch pedal when coming back up sticks briefly. I can feel a little 'stick' at the same time through the throttle pedal and brake pedal. No weird crunching sounds, and happens in neutral and all gears. Changes gear fine. I thought I had chewing gum stuck to the sole of my shoe at first. Nothing unusual on pressing the pedal, it is around mid point upon releasing. Any ideas? Anything I can check?
I’ll maybe have a look. Check the fluid etc. strangely this morning it seems to have righted itself. 🤨🤨
It can go on for ages like that, randomly coming then going. Pumping the brake will provide temp relief if it gets stuck. If it start making high pitched noises at idle with the clutch depressed, that's when you'll want to get it looked at.
1 - 4 of 4 Posts
