I thought i,d show you some pictures of my diy w8 light , i,m going to go for the anni headliner, and as vw dont make the w8 light in black, i,m afraid its going to be sprayed , by me!, any way i,ve split the unit apart and have sprayed the cover and the 3 switches in a matt black, i must say they look good in black!!!!, but the problem is that the black spray has covered the etchings on the switches, i,ve 2 options, either use a sharp needle and a magnifiying glass to scratch all the spray out of the etchings, or get small adhesive circles and cover the etchings up and then spray and remove the adhesive circles which will then leave me with perfect illuminated switches , all be it with a bit of grey where the round sticker was, i,ll have to work out what to do, my first attemp at scratching the etching out, dosnt look too good, but then again it will be aboce you so you may not see the imperfections!!!!, i,ll post pictures of my first switch later on tonight!
worth it or not?, by the way how much is another w8 light, as i need somemore switches[
)][V]
