Hello guys, so I am having issues with my VW I've changed all sensors ie MAP, MAF, Crankshaft.... also have changed in tank fuel pump, fuel filter, oil filter, air filter etc after the initial situation.
After changing all of these parts my car is still doing the same thing.
The issue in term is I am driving fine then the car just cuts out. It was running fine for a couple of weeks then did the same thing wouldn't start up for a couple of hours and have had to spend over 450 on towing back home.
I am hoping that someone on here maybe from Liverpool, Warrington, widnes etc that may have a copy of Vag com and know how to use it to see if they can figure out the issue with the car? If so I would really appreciate your help.
Ps my name is Anthony and from Garston, Liverpool
Thanks again
Thanks again
