Tried replacing the coolant sensor ? Really common problems with these cured my rough starting.
How come youve replaced so many parts?
Looks as if you have bought a car that the previous owner could'nt give a fook about, i would change the temp sensor and replace the battery, not with a cheap one but a good bosch one.New Turbo (brand new) - Previous user error
New water pump - regular service item
New cambelt kit - regular service item
New cam and followers - Previous user error, prob used wrong oil or not regular oil change
New rear wash motor (old one leaked into boot) - common fault
Set of new ND denso glow plugs - should be changed every 100k any way
And I've had it 2 months! - It doesn't exactly give me much faith in VW! I also tried swapping relay 103 with a mates identical car - made no difference, so I am at a loss as to what direction to go in now - the car runs fine otherwise but it is a bit infuriating and embarrassing to say the least!
So, any thoughts or ideas please guys? Any help would be greatly appreciated!
Many thanks
Grant.
Well on my dads bora 130tdi (ASZ engine code) it was on the right hand side of the engine near the back low down. Connection is where a large hose turns the corner, i found a pic somewhere.Well, thats certainly worth a go! I've just had a new battery (old one was reading low anyway), but still to no avail - like I say - only ever happens when its stone cold (ie. overnight!) - can ya tell me where the temp sensor is located please? with pics if possible would be even better! many thanks for your help.
On my dads we found three knackered glow plugs on a 55k mileage car. It was obvious they didnt work they were black and charred, not the like the fourth that was ok brown nice like a spark plug.have you changed glow plugs recently or checked that your getting the correct voltage?
