Could be an issue with the power steering.
BUT its more likely that something in the suspension is damaged. Have you hit a kerb or similar during the ice?
Check the wear of your tyres, are they worn normally? - If abnormal wear is present it would support that it could be the suspension set-up.
I would get a pro to look at it asap as it sounds dangerous.
