1 - 9 of 9 Posts
After topping up a little bit of coolant, I had trouble starting this morning, kept
spluttering and not quite starting after 3 or 4 tries. Made sure all the ht leads and everything was secure and tried
again then boom it started fine first time? I've driven it since and started
fine each time, anyone know what it could of been? So strange...
WD40 on leads is a big fail. WD40 is good for connections i.e. electrical connections to displace water but not to be used on rubber.
WD40 rots rubber and breaks it down.
Use a proper spray like Easy Start or Wet Start/Cold Start by Holts.
I didnt spray them on the leads as that wouldnt really gain any benefit. Just each end at the coil pack and the plugs end.
It's not a major issue anyway, so Im not going to bother getting the easy start/ cold start stuff. Thanks for the tips anyways.
1 - 9 of 9 Posts
