1 - 12 of 12 Posts
This started after I got the MOT check.
When the car is warm it idles at 1800rpm...occasionally dropping to normal idle temperature then shooting back up.
The car also hunts, as in if i dab the throttle it sticks on the same revs for a second before dying down.
If I doing 4000rpm and i put my foot on the clutch, it takes a second before the revs would drop down.
Anyone ever had this?
I bought a new Coolant Temp Sensor and will fit it soon, but wondering if it could be anything else?
Cheers!
i had the same problem, i cleaned my throttle body and the Coolant Temp Sensor and that solved my problem, 3 months down the line it's doing it again. so i'm not to sure what the problem is as i have just checked my tbh and it's clean. but yeah hopefully the Coolant Temp Sensor should solve your problem.
I hope the temp sensor fixes it, mine idles a little high when i start the car at about 1100 rpm, but 1800 is insane. clean the throttle body and maybe vag-com it.
Basic vagcom check gave a running rich error, if that changes anything?
lee can you explain more about the fuel trim code? how do I find out if it has a fuel trim code?
Cheers!
Sounds like you have an air leak, i put my house on it that you have a fuel trim code in the ecu memory
my down pipe has blown before the o2 sensor do you think this would be my problem with the high idle?
i also got 42 miles to 20 quid today :(
i need to change the down pipe asap if you have any time next week lee.
Coolant temp sensor doesn't fit....looks like I have one thats a blue square.
Too old for these new fangled round ones! :(
Sending pm
Right been poking around the car and found a split hose..but I have no idea what it is!
It's under the inlet manifold, to the very right. A small brown/gold pipe runs right under the inlet manifold to it, and it connects to a larger hose which plugs into the right hand side of the engine, think the larger hose is called the main breather pipe?
Any ideas what my split pipe is called so I can get it replaced? Got a big gash in it...
1 - 12 of 12 Posts
