on to more car bits however this time its nothing new just a part that needed replacing. i noticed that my handbrake wasn't holding as well and that the position of it was a lot higher then it use to be. didn't think much of it till i came back to my car that was meant to be parked out side my house yet found it had moved to the front of next doors house by it's self. scary to watch on the camera but so lucky not to had curb any of the wheels of even continued to the lamppost that wasn't far off. long story short i needed to replace one of the handbrake calipers that wasn't retaining back to its position.
ordered a new part and got to work painting them, i did my duel brake upgrade some time ago so wont go into too much detail with how i painted them.
cant say i was too impressed with the finish of the caliper, i know that calipers are usually refurbished then resold but the pitting on this one was a bit much which effects the final finish of the paint job. anyway after many coats this is how it was looking.
then came the install. this was meant to be a quick on and off job but nothing ever goes easy on my car and we quickly found a new problem.
it turns out i ordered the wrong caliper! i did this mod years ago so didn't remember that i have r32 calipers instead of the gti ones i ordered. although the calipers look the same the r32 ones have a modified inside to allow a wider brake disks. so no matter what we tried the caliper was not going to fit and measuring this just confirmed it.
reordered the correct caliper and when it turned up i was sure it was the right one this time, the calipers has a different number on them and you can see the inner side has the machined section.
the bonus to this was that this caliper really was a new one so that when it came to spraying it the finish was so much better. did waste a bit of money on the first spray job but you live and learn and i now know that just because something might look the same doesn't mean it is, but at least the job is done the hand brake instantly felt better.
