so here it is... after a set of power folding mirrors, 2 sets of door modules and 2 VCDS coders i finally got the mirrors to work.
so last time i was talking about how one mirror would fold in as the other one would fold out and that i felt it could have something to do with the positive and negative cable (pin 14 & 15 - purple and blue). i was a little confused before about which pin was which, but after having a closer look at my old mirrors wiring loom i figured out that there is a cap over the numbers which needs to come off first.
to get this cap off, there is a little tab on the side of it which you lift then slide the inner piece with all the wiring out.
so now you can see on the top that each of the wires are numbered. as this is the old non power folding mirror you can see that there is no cable for pin 14 and 15, which makes sense as it doesn't need power to fold.
just as a test i wanted to see if i could remove the cables out so that i would know how to go about it on the car. i ordered myself a set off pin removal keys. don't waste your time as i couldn't get it to work with them and a blade worked so much better. all you need to do is push down on the triangle section of the pin and pull out the cable.
once i knew i could do it, it was time to try it on the real thing. so same process of removing the cap to get to the wiring. here you can see that there are the extra wires for pin 14 and 15.
same process of using the blade to release the wires, i removed pin 14 & 15 and switched them around.
popped it all back in and it works :dance: no need for any extra coding, you dont have to do the passenger side (just driver side) and heres the vid -
click here
so so happy its finally working, really didn't want to be driving around with one mirror shut. i am still having some problems which all seem to be with the passenger side. so the dip mirror goes up instead of down when in reverse, also the one touch feature to the passenger side window doesn't work and finally when the mirrors are shut and the car is unlocked the puddle light for the passenger side doesn't come on but if the mirrors are open it does. bit of a strange one that, so if anyone might no why that is hit me up...!
