1 - 5 of 5 Posts
2000 VW Bora 2.8 V6 4mo
VCDS Version: Release 10.6.3
Data version: 20101206
Monday,24,January,2011,19:58:46:26499
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 261110km/162246miles
Address 01: Engine Labels: Redir Fail!
Part No: 022 906 032 E
Component: MOTRONIC ME7.1 V007
Coding: 00132
Shop #: WSC 31414
VCID: 0D1A1D8B6DD7
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: Redir Fail!
Part No: 1J0 907 379 AB
Component: ESP 20 CAN V005
Coding: 00214
Shop #: WSC 31414
VCID: 71E2617B112F
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B2 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 31414
VCID: 22405E378449
2 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 0F AIRBAG VW5 01 0004
Coding: 12358
Shop #: WSC 31414
VCID: 356A956B25C7
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 925 A
Component: A4-KOMBIINSTR. VDO V04
Coding: 05414
Shop #: WSC 00548
VCID: 2C5CB00FF68D
Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2632059
IMMO-IDENTNR: VWZ7Z0Y2632059
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
29-10 - Short to Ground - Intermittent
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31414
VCID: F0E4E47F9A25
1 Fault Found:
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F4657C3B73B
3 Faults Found:
01312 - Powertrain Data Bus
37-00 - Faulty
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 2L Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 31414
VCID: 840CB8AFBE9D
Part No: 1J2959802C
Component: 2L Tõrsteuerger. FS0002F
Part No: 1J2959801D
Component: 2L Tõrsteuerger. BF0002r
Part No: 1J4959811C
Component: 2L Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 2L Tõrsteuerger. HR0002H
2 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00933 - Electric Window Motor; Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 02403
Shop #: WSC 31414
VCID: 26484227E861
End ---------------------------------------------------------------------
The only persistent faults after clearing them are 01324, 00792, 01274, 00779, 00667.
I think 01324 may be a loose connection plug.
I think 00779, and 00667 are loose wires also.
Not sure about 00792, and 01274.
Other than that we locked all the knock sensors and nothing came back
so apart from the odd electrical gremlin the car is running spot on
Cheers,
John
00792 = is a problem with the air condition system this can be from it running out to a bloacked pipe
01274 = air flow flap positioning motor, again this could be a faulty unit loose wires ect
hope this help
1 - 5 of 5 Posts
