Yes. My speedometer shows 10% too much.quote:
I'm guessing he means "calibrate".
Thanx. That is what I want to know.quote:
you can test all of the gauges in the instrument cluster and all the indicator bulbs/LEDs too, as well as the MFA.
This is slightly different, when the car is under 100 or 400 miles the dealer can reset it to 0 quite easily via the dash IIRC. Not sure how many times they can do this.quote:
Originally posted by Mike
That cant be true as I posted a thread on here once about it
When i first went into the dealer to see the car, there was 13 miles on the clock, upone collecting the car there was 0 miles on the clock
after a thread about it, we came to the following answer
The dealer is allowed by law to turn the clock back ONCE (didnt discuss if it could only be done once) before 60 miles has been clocked up
This is true but if you're being picky its actually 80 miles. I have done this with each of my mkIV's and was even told how to do it by the dealership (admittedly it was my brother). Thing is it only worked once on my anni.quote:
ive heard that it can be carried out twice, but the car has to be under 100 miles.
I am interested in this problem too.quote:
Originally posted by Pablo
I had heard that it is not very difficult to change the milage with and OBD tool, but the catch is you can only put it forward. If the milage entered is lower than what is on the clock the clock crashes on purpose.
Anybody know if this is true?
if I change the milage forward to 9999999 what happend next ? [quote:
Saw something about this on the tdiclub site, whether its kms or miles dont know.quote:
Originally posted by mh
i think the odo goes to 300,000 and then 0 or something like that
Foxy,quote:
Originally posted by foxy
I am looking out for a cheap set of MK4 clocks to 'play' with.
If i get a set, i'll connect them to my car and have a try with the vag-com to see what occurs!
