Depends which tensioner your car has Tdis came with two possible versions :S
Thanks. I've emailed my reg number across tot he seller as they said it's best to check.Depends which tensioner your car has Tdis came with two possible versions :S
Yes, that's right. The services of Mr Singh are being requested. he's seen my spec and I've sent him an email asking if this kit is suitable.Yep, last thing you want to do is strip it down only to find you have the wrong tensioner.
Aren't you running the DSD hot cam? If you are it would be sensible to check how much timing advance you are running before starting to make sure your tune is still spot on after the new belt is fitted
Thanks. I'm sure Bobby will be fine. He's going to look at my cars set up anyway as I do want to tone down the smoke a little and stop the black vapour leak form the IC pipe too. A little tweak and putting it down to around 270bhp should reduce the smoke quite a bit.Ahh, if Bobby is on the case you will be fine. The problem is the pulley can still slip a little even with a locking kit, with the hot cams and a little timing advance you can easily get valves hitting pistonsespecially that it is an interference fit!
The reputation of the OEM plastic impeller pumps seems to have survived long after they were newly introduced (in the Golf 4 era I understand) and the problem traced and resolved with a different plastic material.I would just use the VW plastic impeller pump. At least you know the bearings will last well. Just changed mine after 4 years...still looks brand new. If you use the correct coolant, which I know you are, then it will be fine.
+1 nothing wrong with a decent make of water pump with a plastic impeller.The reputation of the OEM plastic impeller pumps seems to have survived long after they were newly introduced (in the Golf 4 era I understand) and the problem traced and resolved with a different plastic material.
Instances of plastic pump impeller failures on later and current cars seem very rare nowadays
