1 - 6 of 6 Posts
ok i cant find a clear answer on this. i was adjusting my xenons with minimum force, and the adjuster went pop. ive had it out and part of its broken. does this mean a new light or is there somthing i can do??[:(]
Theyre not the same as the standard adjusters I know that much. I will get a pic up once i get them off i just need the time to whip the bumper off. only took me about 20 minutes to do the whole thing last time.
Im praying they can be salvaged so badly [cry]
If you can find a pic of the adjuster it would be helpful, if its the plastic clip that holds the inner of the light to the outercasing then its knackered - I've got one that broke here when it was sent in the post - was NOT happy.
Dan
from what i can see, its the white cogged wheel with the hex head in it that has actually snapped (i found the broken bit on the floor under the car). im not sure if its the clip that holds the inner of the light to the outercasing. i really need to get them back off the car
1 - 6 of 6 Posts
