<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="
[email protected]@
[email protected]@
[email protected]@
[email protected]@5xe" o
referrelative="t" o:spt="75" coordsize="21600,21600"><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Right, I now have the definative answere!!</v:shapetype></v:shapetype>
<v:shapetype stroked="f" filled="f" path="
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600"><v:shapetype stroked="f" filled="f" path="
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Having taken the plunge and purchased the parts I previously mentioned I can confirm that this now works in my car with the Nokia 6310i.</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">It seems that this makes the difference between 'Telephone Preperation' and 'Full Telephone System' as it states in the manual. Why this is not an option in the UK I dont know, but perhaps as 6310i is now an old phone they may not have made one for newer telephones.</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Part numbers & Prices are:</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Interface Box - 1KO 035 729D ?270.83 + VAT</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Cradle - 1KO 035 705B ?87.81 + VAT</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">These were available on back order from VW Main Dealer, but non refundable/returnable. So it was an expensive do at ?421.40 all in!!</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Installation was prity simple, the cradle just clips of and then clips back on again, however the interface box under the Drivers seat carpet was a bit more tricky. Remove the black cover under the seat, disconnect the wires (4 No. with ignition off) to the aerial s election control unit, remove the steel plate on the floor and it is then possibel to lift the carpet just enough to disconnect the existing interface box and install the new one. My existing one was a 1KO 035 729E and was grey where at the new one was green and made by Nokia. Put everthing back and then turn on ignition and goto the main menu to find that Phone is now in the main menu and operation should be as per the handbook in the car. PLEASE NOTE the cradle specifically says 'NOKIA 6310i only' so I doubt that it will work with other telephones. </v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600"></v:shapetype></v:shapetype><v:shapetype stroked="f" filled="f" path="
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">I attach a PDF of pictures of new cradle, menus and operation for you all to look at. In my haste to get it installed I forgot to take a picture of the new interface box! Silly me.</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">It is a great tool in the car now, and will flash up who is calling when you are driving automatically even if you are on MF Display and give you the option to accept or reject the call. It also says when you have a new text message, but it can't display the message on the screen, you have to use the phone for this.</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Hope everyone else who wants this gets it sorted. Any further questions give me a shout.</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">Regards</v:shapetype></v:shapetype>
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
[email protected]@
referrelative="t" o:spt="75" coordsize="21600,21600">DaveL</v:shapetype></v:shapetype>
