1 - 20 of 21 Posts
My TDI 150 2002 , 28K miles with upsolute chip has started to blow out huge clouds of white choking smoke. The smoke is pumping out at idle , on boost and on the over run - just about everywhere. The car seems to produce normal power / performance and boost levels. I'm suspecting a turbo bearing failure, but I've noticed that the water level has dropped below the min level. The oil is normal black, and the water looks pink / clean - no 'cream'. I thought the VNT-17 was an air cooled turbo? As the water level has dropped I'm wandering if the the head gasket has blown, or head cracked? I can't realy take it back on the road as it's just too smokey, so it's grounded until I can figure out what's wrong?
Any advise appreciated.
Turbo will have oil feed and return, no water goes to it i'm afraid so thats not the source of the problem. What does your temperature gauge show?
edit - 'problem' refers to the water loss, smoke as mentioned below may well be turbo related
water loss with no external leaks showing is usually the first indicator of haed gasket failure.Head gaskets can fail between the cylinder and water jacket without mixing oil and water so "no cream" is never concrete proof one way or the other.You need to get your cooling system pressure tested and a combustion detection test done to confirm.Sometimes this model of turbo can become glogged with soot inside the exhaust housing but if it was this you would certainly notice a big drop in performance.
[8-|]
Oh dear. I had a blown turbo on the PD130 through seal failure and it all happened very quickly - a lot of rattling, total loss of power and then bang! Lots of white smoke and all the engine oil chucked out of the exhaust.
So like the experts say, its probably the other? PM Weeloon; he the man.
The smoke has a nasty smell, bit like burning rubber, sticks in your throat.
I think I will take it for a run early morning or late night when traffic is light and check water loss and temperature. The smoke has appeared in a matter of miles so I have n't had time to monitor temp and water loss.
I think it will need to go to a stealer for compression test & cooling pressure tests to find the root cuase of this one. Unfortunately it's not under warranty.
Same as 'Reflex TDI' happened to me with the Galaxy @ 30,000 but I carried on driving to get off the motorway by which time it had dumped all the engine oil out the exhaust & melted no.4 piston.
So I ended up with a complete new engine under warranty which took a bit of sorting as Ford only wanted to replace the damaged parts as they had to get them from VW
I'm hoping this ones a new head gasket, but it may be more to it when its stripped down. I'm thinking of doing the work myself, but I don't know the head bolt torque or have the special sockets for the head bolts. Does anyone have this info?
If I go to a stealer it's ?70 PH, 2-3 days work - say ?1000 and that seems a lot of money for a head job and it may be a lot more?
Can anyone reccommend a TDI specialist how could fix it?
The EGR is a very good point. I don't think it's the turbo because the performance & boost are normal. I don't think it's a cracked head or block or broken ring because it starts ok ie no loss of compression. So it must be head gasket or EGR. It used about a 1 litre of water in about 5 miles. A blown head gasket on a TDI 150 at this mileage is very rare, the turbos normally go 1st.
Does any one know if the EGR pipe has a water cooling jacket on it (Engine code ARL)?
PS Haynes have manual which covers Golf 4 including latter years.
I've found the problem!
The car does have an EGR cooler on it and it has failed resulting in the cooling water being dumped down the exhaust manifold. A new EGr cooler is ?200 and 7~10 days delivery. So I've by passed the water connections and sealed them off with blanking plates. My EGR has been disconnected from new anyway.
i've had a similar problem with my PD 130 - how did you block your EGR valve off - any how to's as i want to do this, as the EGR valve is pointless anyway!
thanks!
1 - 20 of 21 Posts
