1 - 3 of 3 Posts
My passenger side tail light bulb has gone I assume - it doesn't come on with the headlights.
I pulled out the light unit and presumed it was the 3rd bulb down, as that's how it appears when you look at the back of the car. I changed the bulb but it still doesn't work.
I haven't done something stupid like change the wrong bulb have I?
Also, I noticed an empty hole in the unit too - possibly for a fog light? Is it as simple as putting a bulb in this to have a second fog light? Is that even legal?
Guy
Does your front sidelight on the same side still come on,if not the fuse for that side has probably blown?
Yes the emtpy hole is for the foglight not needed under UK law,and it's not even wired up to work.Easy to do but a bit pointless IMO.
Chris.
I'm 99% sure the front sidelight comes on but will check for sure in the morning. It is the 3rd bulb down I change for the tail-light..isn't it?
1 - 3 of 3 Posts
