1 - 20 of 45 Posts
Quote: posted by Jace on 03/11/2004 15:35:58
I shall post a pic once fitted, along with my TT pedals (& dead pedal if finished) & SS Sil strips....Bling Bling[8D]
Any ankle socks to be included [B)] [:D][:D]
Well, they arrived friday, so saturdays job was to fit them[:D]
They came with really good instructions (& glue) on how to fit, took me about 40mins to do, including glue drying time [^]
They are actualy the Tachorange german ones too[^], they came to ?37 inc vat & P&P
I think they look the mutts nuts [8D]
We can probably assume there is no need for a how to if the instructions provided by awesome are good enough :)
Think I might order some today to go with the new gear knob, gear surround and gear shaft I have on the way....
Quote: posted by NorwichV5 on 08/11/2004 14:17:12
Jace, they look well smart.
What sort of a job is it to fit them? Has the dash gone back together ok? By taking it all apart is it not an open invite to squeaks & rattles??
Its dead easy.
Unclip that bit under the clocks
undo the 2 T20 torx under the dials
unclip the dial wires
pull out the binicle
undo the 4 torx T10 on the back of the binicle
pull out dial assembly
slide in rings & glue
leave for 15 min (on gas mk4) for glue to dry
refit in reverse
job done
No rattles or anything since fitting, I was supprised how easy it all was to do, but as I said before the instructions are very good & if you follow them you'll be fine[^]
Just deciding what to get next now [?]
Quote: posted by HuDSoN on 09/11/2004 14:56:24
are they plastic or metal?
CNC'D ALLOY !!!
No pressed steel /fake alloy looking plastic here you know.
Well worth every penny in my view[^]
Quote: posted by evilhomer on 09/11/2004 15:44:55
What make are these rings? If you give me the details I will see if I can locate them cheaper than from awesome... I have my sources!!!
Taken from one of Jade's previous posts "They are actualy the Tachorange german ones too, they came to ?37 inc vat & P&P" :)
The definitely look well fitted and add a nice touch to the dash -
Quote: posted by Jace on 08/11/2004 13:52:24
Close ups as requested.[:D]
Blimey, just noticed my average mpg !!
i wish my fuel gauge would read 198 miles after 1/4 being used!! at that sort of milage im just below half!
1 - 20 of 45 Posts
