1 - 3 of 3 Posts
have replaced ignition switch,now have problem with steering angle sensor,sounds like a piece of paper or tape is rubbing when i turn steering wheel.i have removed sensor and when i turn that it sounds the same i.e a piece of paper rubbing inside.have i broken it ?
thanks
len
It and/or the steering weren't centred when you put it all back together,so as above you've snapped the clockspring[facepalm].
There's plenty of guides available on how to do this PROPERLY if you use Google.
Chris.
1 - 3 of 3 Posts
