Hi, I have a 2007 Pd105 Golf estate with 89k on the clock. It's been regularly serviced and maintained. Recently I've had a grey/white smoke issue which has slowly got worse. I've used vag-com and can't see any issues. I've changed the air filter and oil filter just in case either was clogged. When I unplug the MAF the smoke goes away, so I replaced the MAF with a new bosch one and the smoke came back straight away! It's also burning oil at a much faster rate than usual! On vag-com I've checked fuel temperature, coolant temperature, boost pressure, air intake stays and injector quantity and all seems to be OK, although I'm not expert! Is there anything else that anyone can please suggest before I keep throwing unnecessary time and money at trying things without success? Thanks in advance.
