This is the second template we'll be making available to you. This template is wider than the previously released templates and is intended for use on our wider fixed width theme.
With this template you have more space to play with so we would really like to see some montage, or faded images for this one [Y]
Also wide angled shots would work extremely well with this template.
As per the last posted template - We have left an area on the right of the transparent bar for users to sign the image. The giudelines for this are Verdana font size 10, with smoothing applied - or if using Fireworks, Verdana Size 12. The text must be on the following co-ordinates x819 - y160. Essentially the text must be the same 'size' and 'format' as the slogan text (below the uk-mkivs logo).
As per usual the template is in png format.
The template can be downloaded here : 950 x 200 px Template
