Umm, can I just check, do you mean "flattened" or "fattened"?the end with the most metal showing...ie the end where the foam dosen`t go right up to the hole......and also the end that is fattened for about 6 inches.....
Oops.......[:$][:$].......there is always one crucial letter....and thats the dam one I left out...LOL.........sorry mate.......was "Flattened".....Umm, can I just check, do you mean "flattened" or "fattened"?the end with the most metal showing...ie the end where the foam dosen`t go right up to the hole......and also the end that is fattened for about 6 inches.....
On mine, it is flat on the side with less foam, and FATtened for about 6 inches on the other side (where the foam goes up to the hole).
Thanks again.
Rich,I spent today fitting my upper and lower strut braces and the dogbone mount.
Along with my front brakes (black diamond drilled/grooved and predator pads) i am very impressed!
I was only able to use 1 of the poly bushes as the bolt holes wouldn't line up with the holes in the gearbox due to the size difference in the poly - stock rubber bush.
So i'm gonna get a few mm taken off the poly bush and refit it at a later date.
But even with one bush fitted it feels so much tighter! Now i know what you guys rave on about! The engine just didn't seem to move as much when the key was turned. It felt great.
The steering feels a lot more responsive due to the braces and i'm looking forward to giving my new front end a proper try out tommorow if its dry.
