1 - 6 of 6 Posts
1.8t Bora
Recently brought a reverse camera kit for my 1.8t Bora and all of the old threads are quite outdated now to the point where photos aren't working etc.
I've got a KW-M560BT which has the RCA input for a reverse camera all ready, I just need help on everything in-between 馃槀馃槀馃槀
I was wondering if anyone has any advice for a clean install of this kit, it replaces the number plate light like a Tiguan style.
I've seen people tap into the reverse bulb but can be done using a spare 2pin connector on the rear lights, any insight on this? Cheers
Road surface Wire Geology Soil Asphalt
1.8t Bora
Just need to feed it power and ground. Tapping into the lights is easiest. On the MK4 it's not a problem because it doesn't have bulb monitoring.
you would'nt know where i can get the connector to go into the rear lights do you?
On the back of the bulb holders are a series of pins that are usually used for tow bar electrics, these can be attached onto using spade connectors for a clean install. You'll need power and ground for the camera/light unit itself from the number plate light feed that is already there, and then you'll need power from the reverse light to trigger the camera on the red wire. You can check which terminal is reverse by sticking the car in reverse, with ignition on and all other lights off, and just check for 12v on one of the pins.
1.8t Bora
Right cheers for that, never thought of using space connectors for the back of the lights.
@Projordio, here's some of my posts on how I ran wiring etc for my 2DIN head unit and reverse camera:
how to tap into reverse light
how I ran my wiring from boot lid, to boot and then to center console and dashboard
Automotive lighting White Hood Grille Purple
Bicycle tire Automotive lighting Tire Automotive tire Hood
Motor vehicle Automotive tire Automotive lighting Hood Automotive design
Black Grey Electrical wiring Eyewear Technology
1 - 6 of 6 Posts
