resetting service light
46K views 8 replies 5 participants last post by  mejiaj10014
Killash is this the sequence you are after ?
RESETTING THE SERVICE INTERVAL DISPLAY: (Mk.6)
1. Switch ignition off & press the OO/SET button on righthand side bottom of right cluster dial.
2. Press & hold the OO/SET button & switch on the ignition. The service interval display is now in reset mode.
3. Release the OO/SET button & press the button on the left of the left cluster dial ( button has an icon like two interlocking TV screens) within 20 seconds.
The display will return to the normal mode after a short delay.
