Status
Not open for further replies.
1 - 20 of 122 Posts
All weights with tyres but as you should be aware tyre weights can vary enormously so the table below is indicative only. Where more than one weight is stated an average is calculated. All weights in Kg?s
P.S. As you can gather I?m not an aficionado on wheels so I will stand corrected on mistakes if you would be so kind as to point them out !
15? VW Stock steelie 16.7
15? VW Avus 2 (std TDI wheels) 16.3
15? VW Avus ?
15? Others TBA Please contribute
<o:p> </o:p>
16? VW Stock steelie ?
16? VW <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:eek:ffice:smarttags" /><st1:City w:st="on"><st1:place w:st="on">Montreal</st1:place></st1:City> I?s 17.0
16? VW Montreal II?s 18.0
16? VW Brands hatch 17.0
16? VW Monte carlo 16.0
16? Others TBA Please contribute
<o:p> </o:p>
17? VW Santa Monicas 21.0
17? Rep RS4?s 21.8
17? Rep RS6?s ?
17? Audi TT 5 spoke 19.0
17" BBS RX 18.6 (just for Shiuming!!)
17? Others TBA Please contribute
<o:p> </o:p>
18? VW Anni?s (BBS) ?
18? VW R32 (Oz) ?
18? Rep RS4?s 23.0
18? Rep RS6?s ?
18? Rep R32?s 26.0
18" Audi A8 reps 23.4
18? Oz super leg?s 18.0
18" Oz ultra leg's 18.0
18? Others TBA Please contribute
<o:p> </o:p>
19? Rep RS4?s ?
19? Rep RS6?s ?
19? Rep RS007?s ?
19? Other TBA Please contribute
<o:p> </o:p>
20?> TBA You are mad
<o:p> </o:p>
<o:p> </o:p>
Now in weight order for those of which weights are known; (this bit not edited as of 03/01/07)
<o:p> </o:p>
18?Oz super leg?s 18.0
17" BBS RX 18.6
17? Rep RS4?s 21.8
18" Rep RS4's 23.0
18? Rep R32?s 26.0
Original post below.
Chaps,
Bit mad this but could you weigh your wheels next time you've got one off the car.
Reason being, heavy wheels (however nice they look) have a significant effect on how your car goes.
Big wheels (like mine) although to a degree improve handling have some very negative side effects, these being;
Slower acceleration
Bad fuel economy
Bad handling (big heavy wheels create a massive gyroscopic effect and also the unsprung weight plays havoc)
Bad ride quality (rubber band tyres + increased unsprung weight = boneshaking)
What I'm trying to decide is what route to go down wheel wise and hopefully if this thread developes will help others (yourself included) choose your next set. I blindly went down the route of "I must have those" without fully investigating the consequences before I did so. My main bugbear is that I'm convinced that the heavy rep RS4's I'm currently running have slaughtered my MPG, and that this is due to the weight of the things. Handling is now devine compared to stock but that's mainly down to Mr Eibach et al although going from 195 wide rubber up to 225 wide has obviously helped. [edit] but added drag and also helped to kill mpg.
The general rule of thumb is that air obviously weighs less than alloy wheel and if you up-size, you are replacing air with alloy = not good.
Obviously BBS's are the daddies but not all of us can justify the expense of them. The ATS DTM's are a lightweight wheel so could be considered but in all honesty don't look that nice. It would also be very interesting to find out how much the OEM wheels weigh (including steelies). I have a sneaking suspicion that the Monty 2's will win out here and that VW may have got it right in the first place.
If you are mad enough to play along with this and plonk ye rims on the bathroom scales on your driveway whilst getting raised eyebrows from your neigbours, please could you post the following info :-
1, Wheel type / make (genuine or rep) etc.
2, Make & size of tyre fitted.
3, Brief comments on how you rate yer rims, what effect they have had on the car. etc
Also, if you don't want to weigh yours or think I'm talking rubbish here, I'd more than welcome the debate and would be very interested to hear your views. Please contribute.
[2nd edit]
Thought I'd practice what I preach and I've just been out and weighed my wheels, the results are :-
Wheel = AVUS II; 15.8kg with Michelin Pilot Primacies 195x65x15 on 1.6mm tread
Wheel = AVUS II; 16.9kg with 'Corsa65' cheapy specials 195x65x15 on 7mm tread.
Wheel = Stock steelie; 17.7kg with Dunlop? 195x65x15 on 3mm tread
Wheel = RS4 (rep); 21.8kg with Cooper Avons 225x45x17 on 4mm tread.
Comments; AVUS II's stock wheels, good mpg, poor grip probably due to tyre choice and width.
Steelies; no comment, don't know
RS4 rep 17"; Great grip, poo mpg, ride quality as stock (running -30mm eibachs + sachs gas sport dampers as well)
Quite a difference me thinks.
Great idea and I totally agree, I bought my ACE 132s without really thinking about it, and damn are they a heavy wheel. I don't have them anymore but next time I'm in work with wheels off I'll weigh one and post my result
I suggested something similar in a different thread - standard weights and measures sort of thing, for example, I'm going to weigh my Milltek before I have it fitted, to see if the claims are true about stainless being lighter than mild steel, but then looking at the back boxes, the Milltek appears to be much larger/longer and therefore probably negates any weight saving.
I've weighed one of my standard 1.6 steelies (actually 15" although the tyres say R14 or was it vice-versa?) and I made it 15.6 Kg on bathroom scales. Continental EcoContact CP.
If it helps, www.bbs-japan.co.jp lists weights for all wheels there. Some of them are well under 10 Kg even at 19" and above.
Before I got my wheels I did research this, and I even mailed Continental tyres regarding tyres weights and, I kid you not, the German chap got back to me with weights of the desired tyre at different speed ratings to the nearest 0.01 Kg [:D]
EDIT: There's more to it than overall weight though, gyroscopic effect also depends on how the mass is distributed - more of it at the edge = more gyroscopic effect. BBS has published a study of the MkV GTI wheel, which is made using BBS "Air Inside" technology - basically large portions of it are hollow, to reduce weight at the outer edge.
Interesting topic. My old man recently bought a set of 18" RS4
repros for his 3.2 TT so he could run a set of winter tyres. As a
mattter of interest he happened to weigh the originals for comparison;
the standard wheels with Pirelli P Zero Rossos (225/40 R18) weighed
just under 22kgs whereas the repros with Vredestein Wintrac Xtremes
(225/40 R18 again) weighed just over 23kgs. We both commented how
heavy the wheels in general were, but the rim size is obviously limited
in this case by the size of the brakes. I'll try to remember to
weigh mine when I next have them off (Santa Monicas with Conti Sport
Contact 2s (225/45 R17))
Also, gyroscopic effect is more of a problem at the front because the steering alters the axis of spin, giving corrupted feedback. If you've ever picked up a spinning computer hard disk drive and gently tilted it side to side, you'll know the weird sensation I'm talking about, and you don't really want too much of that in your steered wheels on a road vehicle [:S]
Hi,
I have recently upgraded from avus II to 18" r32. I hav'nt weighed them but the main problem i have is MPG, i'v lost about 10MPG and it's not longer "Shit Hot" off the mark.
As far as I know OZ wheels are supposed to be lightweight!?
I am getting the OZ Hydra... in 17" soon so I must get a weight comparison done, I have currently got Fox Rs3's they probably arent light!
cool... That means I should get a performance increase!
J
Yes but only relatively so - what tends to happen when people buy lovely new alloys is go for a bigger size of wheel than they had before, thereby generally negating any weight saving!
Also, there are different types of alloy wheel, most are cast (molten alloy poured into a mould) but the really lightweight ones are forged (stamped out of a solid billet then machined and finished) - those are mega ???.
Excellent idea. I've spent absolutely ages looking at different wheels in the past few weeks trying to fnd something that I like yet is light and affordable. In the end I may just get some RCs. They aren't my favourite wheel at all but they're lighter than almost anything that is the same size.
I too was wondering whether people would be prepared to weigh their wheels so that we could build a database. In the meantime, have a look here
http://www.wheelweights.net
It's not an exhaustive list by a long way but it's a good source of data for comparing a lot of common wheels.
I've just round to weighing my spare set of wheels, with no tires;
OEM 16" Monty II = 9kg
OEM 17" Audi 6 spoke TT Wheels = 14kg
I think you may be right, both are BBS wheels, and mine are 17". I actually thought 20.9 sounded too light. Anyway, my car is all cleaned up ready for a meet tomorrow, not about to go out and start taking wheels off to weigh them [:)]
ct.p, how about making some sort of table in the first post for easy visibility?
for this same reason i went for original OZ rather than replica rs6
i changed over my 16" monty II's for some 18" OZ canyons. these are not the lighest OZ wheels availble but whilst swapping them over i did not notice them to be heavier than the monties (or not much in it). I keep a close eye on the mpg and i can say i have not notice it change at all. But i will get them on the scales next time i have them off!
Iv had them on since october 2005.  after putting them on, the car felt light i was expectecting it to have a heavy feel. the steering also felt more pin point and mpg figure does not show a increse on my trips
17" Audi TT 5 spoke polished comps (you know the ones!) with nearly new P6000 rubber (Michilin or Pirelli? I forget!) 225-45-17
=19kg
Car does feel noticeably slower in a straight line with these wheels on, compared to the stock 16" Beetle wheels I run for winter.. But the handling is a bit better with the 17" comps. Cant say I notice a difference in mpg..
Just for reference..
16" Monte Carlo wheels with Continental Touring tyres, 205-55-16, 5mm'ish tread all round (standard issue Beetle stuff)
= 16kg
Rolling radius is very close between the 2 types of wheels/tyres. Would 3kg (12kg all round) really make the car feel slower in a straight line I wonder? Its not a massive difference, but definitely noticeable to me.
I ain&#39;t no effin padawan
One thing that you need to remember is that the tyre on a larger wheel will weigh less (for the same rolling diameter)
I went for superleggeras on weight alone. Compared to my santas, thay were 2kg a wheel/tyre lighter.
The car was totaly different to drive after the change.
The mrs PD dropped 4-5mpg going from15's to my old santas, but I think this is partly tyre choice as well.
F1's drink fuel. The track tyres I'm running at the mo are even worse. Grippy tyres+ noisy and high fuel consumption.
I had santas on, and put some a8 replicas on. I didnt weigh them, but they felt really heavy in comparison to the santas. fuel consumption only went down 2mpg, but the really noticable diffence is the noise of the power steering when turning the wheel at slow speeds, I now get a horrible whining noise. On the hunt now for some BBS RC's, as they are supposed to be lightweight.
1 - 20 of 122 Posts
Status
