1 - 7 of 7 Posts
Hi guys, a while ago some pikey smashed my window and nicked my head unit and in the process managed to break my window regulator. At first i thought it was just the white plastic clips had gone so after replacing these and trying the window i found that the wires inside the regulator had minced themsleves :(
I know i should be buying a repair kit with metal clips but which one of these should i got for? (Golf Mk4 1.8t 5dr)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170422433872&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110642327578&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220677696805&ssPageName=STRK:MEWAX:IT
Not really sure what the difference is! (quality?)
Also for the time being i've taped the window up and tried to get the doorcard back on properly but i can seem to get it back on right, the door lock thing (sorry for the tech speak ha) doest pop up like it should when i unlock the door, and when i lock the door it dissapears down the hole rather than staying flat. Its almost as if the doorcard is sitting too high.. but all the bolts fit in ok..?
Thanks guys!
Buy it only from VW or TPS and you won't have to worry about the quality or getting the wrong one.
Chris.
How do i order online?
And also any ideas why i cant get my doorcard on properly?
Don't think you can order online,just ring up any VW parts desk or TPS and give them your reg number,they'll do the rest so no part numbers needed.
Doorcard is almost impossible to get on with the window up,you'll probably have to wait until it's fixed before you can get it on properly.
Chris.
you could also try gsf as i got one from them about a year ago.seemed well put together and was about £40 i think for the whole assembly.
just looked at that one you linked on ebay and the one i got from gsf was the complete unit attached on the metal plate.so youdont have to put anything together.it bolts straight onto the door,tighten the metal clips to the glass and its done .only took about 30 minutes to do from start to finish.
it looked like this,hope this helps. http://www.myturbodiesel.com/images/misc/windowreg6a.jpg
but with metal clips and not the broken plastic ones in the picture[whistle]
1 - 7 of 7 Posts
