1 - 3 of 3 Posts
Hi all,
It seems like the input shaft bearing on my gearbox is on its way out. Whirring noise only when clutch is up, goes away when I push it in.
I called VW with my chassis number and they told me I have an ECW gearbox. I know that the ENJ box has the same ratios, is there any difference in drive shaft flange size and can I buy one of those instead?
Also are there any stretch bolts I need to replace when swapping out the gearbox?
Thanks!
Discussion Starter · #2 ·
Can anyone help? After further research Ive read that all 02j gearboxes have 108mm flanges. But then I also read that the very early 02js had 100mm flanges.
If anyone else has replaced their AGU gearbox which code did you have and what did you change to?
1 - 3 of 3 Posts
