My specialized engineer on Carburettor, told me that he, very often, has changed this type of ICM. Can you imagine how many people spend 230 € (200 for ICM and 30 for the work, and imagine that my engineer is a cheap one (but good on his job)) ? For, only 10 people, is 2300€ ! That is why, there are rich people and poor. Does anyboby believe that the engineers do not know that this module can be fixed in 30 minutes with almost no cost ?
I did not know what, exactly the problem was (my car went some times, like a tractor) . First i visit my normal engineer. He told me two things
1. Change Sparks 2. Clean injectors.
I went for Sparks but each one costs 10€(normally 16€), but it was not for sure that this replacement would resolve the problem and i did not want to spend 40€ for nothing.
Cleaning the injectors costs 80€. It was much for me, also would not, for sure resolve the problem. I found a solution, how to clean the injectors by myself. It is very easy (if anybody want me to saw how this can happen, let me know) The only problem is that i do not know how to unplug the injectors.(Does anybody know how ?)
So i went to the specialized on Carburettor and injections, engineer and finaly he told me that the problem was the Ignition Control Module. I consider that this information he gave me it was very helpful, because i could now find bymyself a cheaper ICM and replace it by myself avoide to pay 230€, so i gave to him 30€ just for the diagnosis he made (he did not ask for it. I just gave to him)
After this, i read about thermocompound pastas. I read, somewere, that the performance (heat decrease) is better between metals than between metal and any pasta like Arctic. So there is a danger to increase heat, instead decrease it. So now i am in contact with somebody from Arctic's site, to inform me if there is a danger and what is the correct way to apply this pasta.
Then i saw this site and i must tell " thanks God that there is internet !" Thank you SIGI and all other people. I saw the same ICM with mine and the same problem. The only problem was that it was not easy to found it. It happened after 1-2 days of searching.
Because my ICM, sometimes misfires, sometimes not, i decided not to open it wet. I , first, will aplly the pasta, in case the problem caused from the fact that the pasta already existed (if there existed), have dried and there is a malfunction because the current is influenced of the heat increase,(not from a wire brake).
So i will test it and will come again to announce the results hoping my post help other people to save money and avoide "professionals" without
conscience !
