Quote: posted by 02 Bora on 16/09/2004 13:42:44
i assume the rub strips are held on by 3M Acrylic foam Tape, or a simlar product.
Therefore if you do remove it, you will also need to remove the adhesive left on the bodywork, in order to be able to re-apply new adhesive and re-stick the rub strip.
Yep that's correct, I removed mine to colour code them. Absolute PITA to remove the old adhesive. I would advise not taking them off. Try and touch it up still on the car.
