1 - 13 of 13 Posts
It differes from car to car based on its age, milage, driver, and location.
Some cars need nothing other than a remap, some need new turbos, clutches, boost controllers, pipe clamps etc....
The list is endless, because as soon as you mod a car from factory spec, the components are not designed with the mod in mind and can wear out quicker.
my 115 i was booked in at R tech for a remap. before i was due to go i got the following.
PD150 inlet manifold, cleaned it out and got it powerflowed.
Allard EGR delete
Allard Catch/breather tank.
de catted
57mm alloy intercooler pipes with silicone elbows.
Replaced and simplified vac pipes with silicone to reduce leakage.
cotten panel filter and cold air feed to air box.
you dont have to do all that but i wanted as much out of mine as possible without changing turbos and injectors. i could`nt afford a FMIC either hence i didnt fit one! A week before the map the turbo poo`ed its pants so i say its wanted a big arse turbo!!
i got my old golf gti turbo re-mapped and had the car for about a year after re-map
and nothing went wrong with the car at all and every thing was standard on the car,
and it rang like a dream mate,
im getting a re-map 2moro evening and i cant wait
A remap wont do damage to the engine but will highlight any weak components for example if your clutch is on its way out the clutch will finish it off, you can remap it without any mods fine but can add mods to get more from it
craig
craig
i second that[:S]
promised myself i wouldnt go too mental after my r-tech remap ....but a cupra r dangled its line and i took the bait.clutch slipped briefly but i blew the cupra away.
now saving for a new clutch [:p]
Don't be tempted to go all out power. I was in a 150 tuned to 220bhp and it was a total pig to drive. My 130 has a map around 175bhp but the power delivery is silky smooth and no extra black smoke.
1 - 13 of 13 Posts
