1 - 20 of 31 Posts
Premium Member
Hey All,
I currenty have a standard alarm on my car, but wanted to get something a little more sensitive (for when kids are leaning against it and messing with it).
I was looking for something with a bump sensor on it as well (if you can get them), and interior sensing). Any ideas on which alarms are good and will do these?
Also, will i need a separate remote for an aftermarket remote, or will they work from my existing key?
Paul
Premium Member
I don't want to encourage the kids though. Would be good to get a clifford alarm. are there any others though?
hi there
I have a viper 480xv remote paging alarm its awesome i had some buggers pinch the wheels off my beloved golf had this fitted and no trouble ever since, ive got a proximity sensor and a shock & tilt sensor and as long as youre in about half a mile of the car it tells you if theres any one by it. thats the good bit BUT if youre gonna park it on the road other cars trigger off the proximity sensor, mines on the drive so its ok and it can make you a bit paranoid. its a bit pricey aswell with all the sensors it came to ?500 fitted but for peace of mind i didnt care.
hope this is of some help to you
cheers bloomus
p.s viper have bought out clifford they are the alarms off pimp my ride
Premium Member
OK, so if i was to go for... say the Clifford Concept 650, would it work off of a separate remote? and how would that work with the key fob? Would i just use my current key for starting the car?
My choice for the best alarm to fit on your Golf would be the only one I truly have enough confidence in to fit to my own car,and that is a Sigma.The only drawback to any aftermarket alarm is that when you arm it,it will also simultaneously arm your OEM alarm without you having to push the button on your keyfob,but when you disarm it,you have to do the new alarm first followed by the old alarm manually from your keyfob.
You would have two new remotes,and if you go fro the Thatcham cat.1 S30,you will also have a keypad to enable you to still arm AND disarm the alarm fully even if you don't have access to the remotes,and this is the only alarm on the market that you can still arm fully even without the remote.
Don't buy second hand alarms as the wiring loom will have been hacked about,and so can make fitting a lot more difficult,and also you won't get any warranty with it,buy new from an authorised dealer to know you will get the alarm properly fitted,and a full UK warranty as well.
Chris.
I've got the clifford avantguard 5.
I would reccomend it definetly.
Omnisensor, which is vibrational.
Dual-Proximity sensor: Internal movement AND external warn away
Tilt/Motion sensor, self explanatory
blackjax, which is like a special Immobiliser.
dont 4get, cliffords have 2 immobilisers generally and Battery back up, not to mention a blooody loud siren!
also Remote Start!!! Good for Cold mornings!!
If you want to say goodbye to your car,than go ahead and get remote start fitted,it seriously compromises the security of your car no matter who fits it,and also be aware that it is illegal in this country.
Oh and any Thatcham category 1 alarm will immobilise two circuits.
Chris.
OK
I have just taken out my insurance with AF and they have told me i have to fit a CAT1 imobilser[:^)]
the car has a factory fitted alarm and imobilser and i would like to know WHY this will not be ok???
IS IT NOT GOOD ENOUGH???
and what imobilser should i be looking at??
i dont want one of these stupid things on the key that i have so stick into a hole inthe dash as that is just poo
ANY IDEAS???
Andy
As I said on a previous post,a lot of insurance companies or brokers don't know their arses from their elbows.You have a V6 4MO don't you,which has the EQUIVALENT of a cat.1 alarm on it as mine does,or rather it was recogised as such some 8 years ago when they were first fitted,but I don't think they qualify as that now.I must stress I'm not sure on this last point,but will do my best to find out.
A Cat.1 is an alarm as well as an immobilisor,and works by immobilising the car only normally 30 seconds after you turn the ignition off,but it still needs a push of the button to set the alarm fully.When you return to the car,you push the button again to disarm the alarm,and have 30 seconds to put the key in the ignition and start the engine before it immobilises the vehicle again,there is no seperate operation to perform involving touch keys,that is normally only found on Cat.2s,which are purely immobilisors.
Chris.
So what you are saying i could tell them to bugger off??
i have the alarm with all the micro switches on the doors and bonet but without the internal sensors
should this be enough if i could get a company to validate the system that is fitted??
Andy
Dent Reform, I know on a Golf that is a GTi & above the alarm that is fitted to it is a Cat1.. But as you motor was originally a 1.6 you might need to check with a dealer or an alarm shop if it's a Cat1.
If you do need to get an aftermarket immobiliser I don't wise to have a stick in one your only other option is a Cat1 alarm,
A Cat.1 alarm must have direct triggers on all the entry points into the car (doors,boot and bonnet),it must have some sort of internal movement sensor,it must have a battery backup siren,and it must have a two point immobilisor that MUST passively arm,if you fail on just one of these,it won't be recognised as a Cat.1.
Although they were one of the most secure cars you could buy when fitted with all this back in the late 90s,someone with my knowledge could get past any OEM security features in a very short time.No two aftermarket security devices are fitted in quite the same way,and will take considerably longer to defeat than any OEM system.
Chris.
I had spoken to a company that AF advised me to use and the guy was not much help atall
ok he was a compleat PRAT
i asked him about this and all he tried to do was flog me a system that was "THE BEST" or money back and told me that if anything was stolen out of the car then it would be replaced and so on and so on
car could NEVER BE STOLEN bla bla bla
total cost 1100 quid[:O]
and that 2 days befoer x-mas LOL
as you gather i told him thanks and i would be in contact, NOT!!!!
Andy
I know it was a clifford with all the bits and bobs with pinpad and remotes and the likes[:^)]
this is one aera where i have NO clue as to what is good or garbage LOL
any links to any good places with this system you are on about??
Thanks budy
MASSIVE HELP
Andy
1 - 20 of 31 Posts
