Finished the other side tonight.. [
]<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
The car loom colors are different for both the drivers and passengers sides...something like <o
></o
Green/White/Brown & Blue/White/Brown not ness in that order..
But the seat air bag connectors you need to wire up the colors are the same.<o
></o
I firstly disconnected the battery -neg terminal.<o
></o
Then removed the seat.<o
></o
Then the connector from the base of the new seat, by releasing the purple cable pin retainer and pressing the little barbed pins in and they just come out. Then just cut the pins of trying to leave as much cable to work with as possible..<o
></o
Then striped the ends of each cable back and tinned (solider) the ends, once cool slipped on some heat shrink sleeve.<o
></o
<o
></o
Please excuses the photos only had my phone camera and didn't relies its out of focus.. [:S]<o
></o
You can see the difference in the old socket on the left (4 pin (1 not used)) and new one on the right (3 Pin)<o
></o
<o
></o
Then prepped up the new pins that came with the new connector.<o
></o
<o
></o
Then solider them together<o
></o
<o
></o
and once all three are done, pulled over the sleeve and gave it a little heat with a hot air gun.<o
></o
<o
></o
then placed them into the connector as shown...<o
></o
Refitted seat, connected battery and held my breath .......heyhoe it all works... [
]<o
></o
hope this helps.
O yes I will not be held responsible for any errors or airbags injures that occurs during install
Just check on your old seats once unbolted not removed, i.e still connected.<o
></o
The colors of the wire on the seat and which wire colors they are on the car loom.
Brown - Brown etc
And refit the same, Thats all I did..
