any ideas or tips regarding this! when i push my wiper switch back the wiper moves,and i hear the motor tryin to send the water into the back but nothing happens,any ideas how to fix this on my golf!
thanksssssss
Very common fault on the MK4s [:mad:]
You can take the motor out and try and replace the fixings around the water feed and the motor, otherwise its a new motor and they are eeeeexpensive. Best bet would be a salvage yard
You can buy rear wiper fixing kits from VW for ?25 which replaces all
the internals, full instructions supplied and a doddle to fit!
Isn't there one part in that kit that's only plastic/rubber though, so
will corrode/split/whatever again. I think there's a bracket or something that
some suggest to buy from homebase or something to make it a permanent
fix.
(Side note: The fact that vw do the kits with instructions inside
implies that they know it's a common fault - a design fault if you will
- but they still do nothing about it!)
i just had a look at my rear windscreen washer! now here goes
water is gettin to the back to the motor comes out the pipe you see,but when i reconnect it,it doesnt shoot onto my window! do i need a new motor or would it be blocked
You can buy rear wiper fixing kits from VW for ?25 which replaces all the internals, full instructions supplied and a doddle to fit!
David,
You don't happen to have the part number for this repair kit do you?
I checked with my local dealer and they have no idea of such a kit existing ???
also check the c piller, mine and my mates had gone there, there is a swivel joint that is near the rubber for the boot where the wires go through( left hand side) if gone there just pull some pipe through either side, then remove the swivel joint, with that gone, the pipe willm pop into place where it used to go, if that makes sense lol, might have to pop off the cover to the c piller behind the seat to help/
